My Dodge Intrepid has been acting up as of late when I make sharp right turns it turns off. I heard it was an electrical issue but not sure.
Nov 23, 2009 at 12:46 PM
JDL
✓Experienced Mechanic
Welcome to the forum, with engine running, shake all the battery connections, see if it makes any difference? Also, shake the wiring for the ignition switch, see if there is any reaction. You might also check for trouble codes.
