1995 Dodge Intrepid Car won't start but rolls over
180,000 MILES • 6 CYL • FWD • AUTOMATIC
KAYLIE&ZACH
We have a '95 dodge intrepid and everything was working great, we just had the oil and tires changed, but a week after all that the car won't start, it died on the side of the road and will make all the right noises but will not start...any idea where to start? we'ver heard alternator, fuel pump, starter, but we don't have a enging code reader.
Sep 20, 2010 at 1:09 PM
  • 75,988 POSTS
Cranks but no start condition-do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 20, 2010 at 4:44 PM
