1995 Dodge Intrepid car want start or turn over
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZIMMERMAN
i turn the key and nothing happens the battery is charged and every thing comes on the fule pump i here and every thing that runs of the battery works what to do?
Feb 20, 2008 at 6:05 AM
  • 75,988 POSTS
1995 Dodge Intrepid car want start or turn over: Do you mean it cranks over and refuses to start or won't crank over at all.
If it won't crank over-double check the battery and its connections-could be also the starter itself,starter relay,transmission range switch/neutral safety switch, and ignition switch.
Cranks but w/n start-check the fuel pressure and spark, then comeback and tell us what's missing.
Feb 20, 2008 at 6:15 AM
ZIMMERMAN
it's the starter itself i hit it lightly with a hamer and it started.
Feb 20, 2008 at 6:27 AM
