1995 Dodge Intrepid Car doesn't want to move
CRANKBREAKER
Transmission problem
1995 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 126K miles
The car starts and runs well but doesn't want to move. In the forward gears if you put it about 1/2 to 3/4 throttle it may lurch forward. In reverse it will only lurch if you gas it while it is going into gear. Unlike most cars you can't feel this going into gear.
The guy I got the car from had just had the rear brakes replaced. The car rolls fine when in neutral and not running. FYI
Apr 2, 2010 at 6:33 AM
2CARPRO JACK
  • 11,533 POSTS
If it rolls in neutral it isnt likely the brakes.Sounds liek the trans may have gone out, not uncommon for those vehicles.You could try a service first to be sure the filter isnt plugged up with clutch material.Or even try having the computer scanned to see if it has recorded any trans fault codes.
Apr 5, 2010 at 1:00 AM
CRANKBREAKER
Thanks for the response Jack. Could it be the torque convertor?
Apr 5, 2010 at 8:49 AM
2CARPRO JACK
  • 11,533 POSTS
Possibly, but if it is, the odds are that the trans has metal contamination from it falling apart
Apr 5, 2010 at 9:05 AM
