1995 Dodge Intrepid anti theft
RUSS WENZEL
Computer problem
1995 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
car will start but only run for a couple seconds, then will stop and lights will flash and horn will blow like the anti theft is activated. Have tried everything to deactivate theft system but no luck. Have even replaced anti theft module under dash panel. Would this be a computer problem or something else?
Sep 6, 2009 at 7:56 AM
CARADIODOC
  • 34,415 POSTS
Try unlocking the passenger front door with the key. If that solves it, suspect the switch in the driver's door is defective or the linkage is broken or disconnected.
caradiodoc
Sep 6, 2009 at 7:25 PM
