The TCM is located next to the battery on the driverside fenderwell. It controls the transmission and monitors any information from the sensors on the transmission, Including the speedometer which I assume is not working now. When the TCM fails, it kicks the transmission into "safe mode" to allow you to drive it to a shop without causing anymore damage. You should be able to find this used in a salvage yard for about $40. It takes about 15 minutes to disconnect the battery, remove it from the vehicle, remove the plug by loosening the bolt that holds it in, and removing the four long screws that mount the module to the car. Replacing the TCM will effectively eliminate many possibilities to the issue your having and a very good chance of fixing your issue all together.
SPONSORED LINKS
Wednesday, February 6th, 2008 AT 10:00 PM
