1995 Chrysler Intrepid Turn Signals Out
ALACIA
1995 Chrysler Intrepid, 295,000 kms, automatic, 3.3 Litre engine; signal lights don't work, hazards don't work either. The dashboard indicators don't come on at all. None of the bulbs are burnt out, and the fuse is also still good. What could be the problem?
May 19, 2007 at 9:18 AM
  • 75,988 POSTS
[quote:2d0787cc3a="alacia"]1995 Chrysler Intrepid, 295,000 kms, automatic, 3.3 Litre engine; signal lights don't work, hazards don't work either. The dashboard indicators don't come on at all. None of the bulbs are burnt out, and the fuse is also still good. What could be the problem?[/quote:2d0787cc3a]
Try checking the flasher unit or it might be a ground problem.
May 19, 2007 at 7:13 PM
Suggested Repair
Check the turn-signal flasher unit and inspect for a ground problem.
Conversation Summary
The owner of a 1995 Chrysler Intrepid reports that the turn signals and hazard lights do not work and the dashboard indicators do not illuminate. The bulbs and fuse were checked and are good. The expert suggests checking the flasher unit or a possible ground problem.
