1994 Dodge Intrepid Will not start
RTHALMANN
Electrical problem
1994 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 230K miles
I have a 1994 Intrepid that will not start. When I turn the key the fuel pump does not run. Engine cranks but no spark. Fuel pump runs if relay is closed manually. No power to crank or cam sensors but the sensors are good. No power out of the PCM to the sensors. PCM seems not to be closing fuel relay coil circuit. Strange thing, no check engine light when key is turned to on. I don't remember exactly but I thought the light should come on for a short time then go off. Ideas?
Jul 10, 2008 at 3:29 PM
JADO351
  • 9 POSTS
Sounds like the same prob. I am having.
I have no spark, no power going to the coils. I changed out crank and cam sensers, even sent PCM in had flashed and reprogramed. I've been told I need to have the VIN number put into the PCM to match the car. I hooked my laptop to the car and when I do a VIN check it comes up N/A but program won't let me put it in. if I find out anything else I let you know. I'm lost to what the prob is
Jul 10, 2008 at 3:46 PM
WUDPECKER
  • 6 POSTS
Sounds like a bad PCM.
Have you changed battery lately?
My 1993 Intrepid just quit starting, like yours, about a month after I changed the battery. Suspect I may have shorted something in the process.
Had to replace the module. Expensive.
Oct 26, 2008 at 12:35 PM
