1994 Dodge Intrepid water pump
146,000 MILES • 6 CYL • FWD • AUTOMATIC
CARSTOP1
my water pump is leaking with the car off from what appears to be a weep hole at the bottom. Does this require replacement and is there any additional items that may need replacement or cautions to watch out for?
Jul 27, 2008 at 6:18 AM
DOCFIXIT
  • 18,828 POSTS
Yes replacement is necessary. You may want to replase hoses and thermostat. Flush the cooling system would be good idea also. Are you DYI ? on line repair manual on this site will be helpful.
Good luck
Thanks for donation
Jul 27, 2008 at 6:38 AM
