1994 Dodge Intrepid shifting
1994 DODGE INTREPID
10,000 MILES • 6 CYL • FWD • AUTOMATIC
DOWNESGW
occasionally the transmission will not shift into overdrive. if you stop and kill the car it usually will shift through okay. my brother says change oil and filters. car place says it's modules that need to be replaced. that will cost around 600 dollars
Apr 7, 2010 at 2:00 AM
  • 110,241 POSTS
Have you taken it to a transmission tech? It could be a sensor or solenoid, but it could also be the torque converter.
Is the trans fluid presently clean and full? Chances are a service won't fix it, but it is the cheapest place to start.
Apr 8, 2010 at 3:36 AM
