1994 Dodge Intrepid SENSOR
ERNROD
Engine Cooling problem
1994 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 180K miles
COOLING FANS NOT COMG ON, NO SWITCH, FANS DO WORK, RELAYS & FUSE GOOD, TOP RAD HOSE DOES GET HOT, VOLTAGE ON ETC PLUG APPX. 5 VOLTS, RESISTANCE ABOUT 3K OHMS ON SENSOR YET FANS STILL DO NOT COME ON. YES TEMP IS OVERHEAT... POSIBLY THE ETC SENSOR?
Sep 14, 2009 at 3:19 PM
CARLIFE65
  • 200 POSTS
you have a bad coolant temperature sensor
https://images.2carpros.com/forum/automotive_pictures/420105_0900c1528008defb_1.jpg
https://images.2carpros.com/forum/automotive_pictures/420105_0900c1528021a880_1.jpg
https://images.2carpros.com/forum/automotive_pictures/420105_0900c1528021a881_1.jpg
Oct 24, 2009 at 7:02 PM
