1994 Dodge Intrepid Premature brake wear
90,000 MILES • 6 CYL • FWD • AUTOMATIC
PLS2870
I replaced the brake pads and rotors a couple months back, less than 5,000 miles and it sounds like they're grinding metal on metal. I cleaned the rotors with brake cleaner before they were installed. Any idea what might be the cause of the early wear?
Thank-you
Oct 15, 2009 at 4:02 PM
CH112063
  • 1,320 POSTS
Sometimes the pads get a piece of dirt, and debris in their surface and make noise, but better check to make sure. 85% of the car is front weight and it is a safety issue. If they were inexpensive, it is for the reason that they have no noise garantee. And may be normal. ok
Oct 16, 2009 at 8:49 AM
