1994 Dodge Intrepid gy
MEGACHARGER450
Engine Mechanical problem
1994 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
how do i put a new motor into this car. old motor is already out. when i go to put the new one in the back of the motor and the transmission will not come together. if i put bolts in it and try to tightin them then the motor will not spin.
Apr 30, 2009 at 12:06 PM
OBXAUTOMEDIC
  • 3,715 POSTS
[quote:87fb983086="megacharger450"]Engine Mechanical problem
how do i put a new motor into this car. old motor is already out. when i go to put the new one in the back of the motor and the transmission will not come together. if i put bolts in it and try to tightin them then the motor will not spin.[/quote:87fb983086]
Did you remove the Torq Converter? If so when you put it back in did you make sure it was all the way in. There is usually 3 steps when putting converter in. After you put the converter in you need to spin it slowly while pushing in easyly. It should slide in 3 steps while doing this.
Also are you making sure that the converter studs and the Flywheel holes are lined up.
Apr 30, 2009 at 1:02 PM
