1994 Dodge Intrepid fuel problem,,and hard starting
135,000 MILES • 6 CYL • FWD • AUTOMATIC
FJCSMC
my intrepid will start and run,,and runs fine now that the fuel filter was changed,,but when u run it ,,turn it off for a short time then try to turn it on it will not start or if it does it starts hard,,sometimes taking several times to start if it does at all,,sometimes you have to wait a while we put some fuel injector cleaner in it and we still have more time to let it run thru...
Feb 23, 2008 at 2:39 PM
BMRFIXIT
  • 19,053 POSTS
check relays under hood
fuel pump and ASD relay
check crank sensor
Feb 25, 2008 at 9:48 AM
