1994 Dodge Intrepid engine will not fire
BRUCE STEPHENS
  • 1994 DODGE INTREPID
  • 6 CYL
  • FWD
  • 140,000 MILES
I put a crank sensor in and coilpack and still will not fire in cold weather if you keep cranking engine over and over in time it will fire or if put it inside with heat it will fire right away
Saturday, December 5th, 2009 AT 9:15 AM
JDL
  • 16,098 POSTS
Welcome to the forum, When it refuses to start, have helper crank it, while you check for spark at the plugs, if no spark, check primary voltage at the coil, dark green wire with orange tracer. At the injectors, check the same wire for voltage. Check for trouble codes. You may be able to get mil codes by cycling the ignition switch. You turn the key till the dash lites come on, no further. Cycle, on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes. Also, use a gage and check fuel pressure.
Saturday, December 5th, 2009 AT 9:52 AM
