1994 Dodge Intrepid electrical problem
170,000 MILES • 6 CYL • FWD • AUTOMATIC
SCRUG
  • 5 POSTS
hi, 1 month ago my car had an electrical problem, flasher, ctsy light, dash gauge ( light and indication), wiper, electrical door lock and electrical trunk opening stop working all at the same time.ive decide to unplug the negative of the battery and everything came back to normal except flasher than 3 days after its goes off again ive did the same thing and work. now i have to do this every 3 days. please help me fix it im tired and i have kid's to protect i dont want it to goes off when i need the wiper it could be dangerous.
Dec 27, 2008 at 9:08 AM
  • 110,251 POSTS
Hi:
It sounds like you have a bad body control module (BCM). When you disconnect the battery, you are reseting it. You will need to have it checked by a mechanic that has the proper test equipment.
Let me know if this helps.
Dec 29, 2008 at 8:00 AM
SCRUG
  • 5 POSTS
ive show my car to a mechanic... he said that he plug a bdm on it but he found nothing the computer looks ok he said and he was unable to told me whats the problem so i hope you can :)
Dec 31, 2008 at 4:29 AM
  • 110,251 POSTS
Then ,there has to be a ground probem causing this. That many things don't stop working at the same time. Check the grounds to the engine block, body... Something is loosing connection. Also, under the hood there is a power distribution box. Make sure the plugs are all tight.
Let me know what you find.
Dec 31, 2008 at 7:44 AM
SCRUG
  • 5 POSTS
ive check the poyer distribution box connection's, they are all tight. ive check all the ground in my car to the engine some was in bad shape ive fix them but the problem came back yesterday and i was on the highway without wiper and bad weather.....
Jan 7, 2009 at 3:11 AM
