HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Intrepid
Engine
Symptoms
Not Running
1994 Dodge Intrepid car wont start
TRIZZ4321
MEMBER
1994 DODGE INTREPID
6 CYL
FWD
AUTOMATIC
125,000 MILES
Hi, my car will turn over, but will not start. What can be the problem? Thansk
Tuesday, February 5th, 2008 AT 9:43 PM
MECHANIC
Check the fuel pressure and report back with your readings before we can continue.
Or do this spray carb. Cleaner into the throttle body and tell me what happened.
SPONSORED LINKS
Wednesday, February 6th, 2008 AT 1:54 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1994 Dodge Intrepid Will Not Start
Electrical Problem 1994 Dodge Intrepid 6 Cyl Front Wheel Drive Automatic 230k Miles I Have A 1994 Intrepid That Will Not Start. When...
Asked by
rthalmann
1994
DODGE INTREPID
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1994 Dodge Intrepid Engine Will Not Fire
I Put A Crank Sensor In And Coilpack And Still Will Not Fire In Cold Weather If You Keep Cranking Engine Over And Over In Time It Will Fire...
Asked by
bruce stephens
1 ANSWER
1994
DODGE INTREPID
1994 Dodge Intrepid Intrepid (3.5l Auto) Wont Start....
According To The Shop Manual, The Pcm Wont Turn On The Following Relays ( Fuel Pump, Auto Shutoff ) If A Signal Is Not Recieved From The...
Asked by
xearo
1994
DODGE INTREPID
My Car Won't Start Unless Cruise Light Is On
1994 Dodge Intrepid Car Will Not Start Unless Cruise Indicator Light On Dash Comes On. 3 Wires That Go To The Coil Get Pulsed To Ground By...
Asked by
vlriggs1
1994
DODGE INTREPID
Car Wont Start
The Car Ran Fine Last Night No Issues. Went To Start Up This Morning And It Would Turn Over But Not Fire Really Confused.
Asked by
bob04
1 ANSWER
1994
DODGE INTREPID
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
