1994 Dodge Intrepid Car overheats!
DULCEFRESH
  • 1994 DODGE INTREPID
1994 Dodge Intrepid 6 cyl Automatic 95000 miles
I have a 94 dodge intrepid. It heats up. First of all there is no radiator cap in radiator there is only a overflow bottle. There was a small crack on top of radiator we put plastic weld on it it fixed that. But the prob is it overheats in a matter of 20 minutes and all the water goes out and steam comes out of the upper hose (which is disconnected, we dont where it goes. As we just bought car) pls. Help thanks.
Friday, July 23rd, 2010 AT 11:16 PM
  • 109,885 POSTS
Have you fixed the problem? As far as the question, when you say the upper radiator hose is disconnected, are you refering to the small hose from the overflow?
check out our tip sheet on this common issue at https://www.2carpros.com/first_things/engine_over_heats.htm
Saturday, July 24th, 2010 AT 12:19 AM
DULCEFRESH
I was talking about the 2 small hoses that are on the overflow bottle the top one isnt connected and when car overheats steams comes out of the top one.
Saturday, July 24th, 2010 AT 1:13 AM
  • 109,885 POSTS
That makes sense. Have you tried replacing the thermostat?
Saturday, July 24th, 2010 AT 1:29 AM
