1994 Dodge Intrepid
BRAD_TI
  • 1994 DODGE INTREPID
  • 6 CYL
  • 192,000 MILES
I will drive my car for 30-40 mins and when I come to a stop rpm's drop to about 500 and the car will stall. It takes about 30-40 mins to cool down, and will start back up. Dealer said that it was a fuel pump problem. I replaced the fuel pump, fuel filter, fuel pressure regulator, I also changed the coil pack, and the spark plugs and wires, without any change in the behavior of the car. Any advice?
Wednesday, July 21st, 2010 AT 2:45 PM
  • 109,885 POSTS
Has anyone checked the crank sensor? Also, has the check engine light come on?
Thursday, July 22nd, 2010 AT 9:22 PM
BRAD_TI
The crank sensor has not been checked and the check engine has not come on.
Friday, July 23rd, 2010 AT 12:59 PM
  • 109,885 POSTS
Check the crank sensor and let me know what you find.
Saturday, July 24th, 2010 AT 1:04 AM
BRAD_TI
Ok, I replaced the crank sensor and it doesntseem to drive but when I put it in gear the rpms drop from 700 down to about 450 to 550 any ideas
Sunday, July 25th, 2010 AT 10:50 AM
  • 109,885 POSTS
Is the check engine light still on? Have you had it scanned?
Monday, July 26th, 2010 AT 1:03 AM
BRAD_TI
Last message was a little unclear. It doesnt seem to die now after the crank sensor was changed. And the check engine light does not come on. It is just running like crap now.
Monday, July 26th, 2010 AT 8:44 AM
  • 109,885 POSTS
I'm glad it didn't come back on. Have you checked fuel pump pressure and for vacuum leaks?
Monday, July 26th, 2010 AT 10:37 PM
