1994 Dodge Intrepid Front Roar Vibration
MSHAZEL40
I have a 1994 dodge intrepid with a 3.3 engine.i put tie rods on inner and outer.havent had an alignment done yet.i have this bad sound like it is loose and when im driving slow it its really noticable.when i drive on the highway at 70 it quits .but the whole car vibrates.i have a roaring noise in the front too.any inf owould be appreciated.Thanks Patricia
Aug 16, 2007 at 12:50 PM
SERVICE WRITER
  • 9,123 POSTS
Need to double check those inner tie rod end bushing at the firewall, have seen these be deceiving when thought to be tight. This may be related to the vibration. However there may be a loose wheel bearing causing both the vibration and the roar. A badly chopped tire can also cause a similiar roar.
Aug 17, 2007 at 12:35 AM
Suggested Repair
Recheck the inner tie rod end bushings at the firewall, since they can appear tight when they are not. Also inspect for a loose front wheel bearing and a chopped or damaged tire, either of which can cause the roar and vibration. An alignment is still needed after the tie rod replacement.
Conversation Summary
The owner of a 1994 Dodge Intrepid with a 3.3 engine replaced the inner and outer tie rods but has not had an alignment. A loose-sounding noise is most noticeable at low speed and fades around 70 mph, while the car vibrates and a roaring noise comes from the front. The expert recommends verifying the inner tie rod bushings at the firewall and checking for a loose wheel bearing or a badly chopped tire.
