1994 Dodge Intrepid
DANNY32682
  • 1994 DODGE INTREPID
Transmission problem
1994 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
The transaxle makes a loud knocking sound Ithaught it might be the engine but the knocking doesn't increase with the engine speed only when the car is accellerating. It seems to run and pull fine but I know something is on the brink of failing any ideas.
Tuesday, February 16th, 2010 AT 7:22 AM
DOCFIXIT
  • 18,828 POSTS
HI
So if you let off gas say at 40mph knock goes away? Hit the gas it's back? Any vibration? Any noise while making tight turns?
Let me know
Thanks for donate
Tuesday, February 16th, 2010 AT 8:55 AM
DANNY32682
Yes if I let of the gas it goes away. There is no vibration and not any noise in tight turns.
Tuesday, February 16th, 2010 AT 9:02 AM
DOCFIXIT
  • 18,828 POSTS
O.K. Check inner CV joints for play or torn boots. If good then comming from trans axle. Pull cover plate between engine and trans see if torque convertor bolts are tight
Tuesday, February 16th, 2010 AT 9:08 AM
