1993 Dodge Intrepid timeing
RALPHIE13
Engine Mechanical problem
1993 Dodge Intrepid V8 Two Wheel Drive Automatic
put new water pump on heard somthing spin how can i be 100% sure its still in time. how can i check timing marks. thank you
May 18, 2010 at 4:58 AM
  • 75,988 POSTS
3.0L
Ignition timing should be 12BTDC
Place gear selector in Neutral or Park position. Turn off all lights and accessories. Connect inductive pick-up timing light to No. 1 cylinder.
Start and warm engine to normal operating temperature. Disconnect engine coolant sensor lead wire. Radiator fan should come on, and CHECK ENGINE light on instrument panel should illuminate.
Check timing at crankshaft pulley. If timing is within 2 degrees of specification, DO NOT adjust ignition timing. See V6 IGNITION TIMING table. If timing is not as specified, loosen distributor hold-down bolt, and turn distributor housing until specified timing is obtained.
Recheck timing after distributor hold-down bolt has been tightened. Reconnect coolant lead wire. Erase any fault codes. Remove diagnostic equipment.
May 18, 2010 at 6:50 PM
