1993 Dodge Intrepid Starting Problems
FILLMORE23
1993 Dodge Intrepid 150000 miles
First I do not see the battery, can you tell me where it is located? Also the car has a postive & neg post but the veh will not start. Any ideals?
Jul 18, 2009 at 3:09 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_93_dodge_intrepid_1.jpg
The battery is under the hood, driver side front. Are you saying the starter won't even crank? If that is the case, make sure the battery has a full charge and the cables/wires are ok. There is also a starter relay in the power distribution center, you could do some testing there. Did you try cranking in neutral? Any testing make sure the tranny is in park or neutral and the e-brake is set.
Jul 18, 2009 at 3:35 AM
