1993 Dodge Intrepid Rear Defrost
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
REAR_WINDOW
After some not so smooth electrical work on my car, the rear defroster was shorted out. There is no power coming into the console in the dash. The relay works fine and the wiring is fine all the way through the rear window. I tried tracing the power wire back to its source, but after it goes through the firewall I can't find it on the other side. Any idea where the power source for the rear defroster originates from? I can't even find a fuse, that would certainly be an easy fix, but none of the fuses are blown. Thanks.
May 26, 2008 at 7:10 AM
MERLIN2021
  • 17,250 POSTS
The fuse is #6 10amp
May 26, 2008 at 7:31 AM
