1993 Dodge Intrepid Flashers and Blinkers not working.
MEHURD
Electrical problem
1993 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
I just replaced the battery in the car, and now the flashers and blinker lights do not work. I am trying to replace the flasher in the car, but I cannot find where it goes, or how to get to it.
Can you help me find the old one, so I can replace it with the new one I have purchased?
Sep 6, 2008 at 6:58 AM
MIKEPLAGA
There is a small wire that is connected to the positive side of the battery terminal that powere the flashers, make sure it's tight. It's almost like they forgot to put flashers on the car then added them later.
The flasher is located under the dash above the ac duct next to the fuse box, it's a black unit that looks like a relay with 5 pins on it, Chrysler flasher part # 47600060 is stamped on it.
Sep 6, 2008 at 8:24 AM
