1993 Dodge Intrepid Cranking issues!!
135,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHNNY1333
Car ran fine, drove it 10 miles. Let it sit for a week, went to start it and there was nothing. No power to the starter, fuel pump and the dashlights aren't working. Replaced battery with a new one. Had starter and alternator tested, both came back good. Changed neutral safety switch. When I turn the headlights on and try to crank it, the headlights stay bright. All fuses and connections are good, even the grounds. I am confused and need help please!!
Sep 14, 2009 at 4:05 PM
  • 75,988 POSTS
Check fuse B 20amp if okay test the starter relay and ignition switch
https://images.2carpros.com/forum/automotive_pictures/12900_starter_relay_6.jpg
Sep 14, 2009 at 10:19 PM
JOHNNY1333
I changed the ignition switch and I tested all fuses everything is good
Sep 15, 2009 at 1:26 PM
