1993 Dodge Intrepid car smokes white smoke only when hot
1993 DODGE INTREPID
KLSMITH49
Engine Mechanical problem
1993 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
I have low compression in my #4 cyl highest test was 115 lowest was 95 all other cyl. 120
when I drive the car it starts to smoke when the engine is hot. I had just finished replacing the fuel injectors so the car had been sitting for a mounth or so itll I could fix it.
Aug 30, 2009 at 10:33 AM
White smoke indicates you're burning coolant-get it block and pressure tested to rule out a blown headgasket, cracked head or block
Aug 30, 2009 at 10:41 AM
