1989 Dodge Intrepid Spark Plugs
130,000 MILES • 6 CYL • FWD • AUTOMATIC
MATT1821
I just changed my spark plugs and on the 5th one i found that there was a pool of oil at the bottom and the plug itself was covered in it as well, what could this be? Also after replacing all of them, the car now shakes and wobbles at idle.
May 8, 2010 at 9:34 AM
  • 75,988 POSTS
Check the valve cover gasket if the oil is outside the combustion chamber if its inside could be guides/seals/stems/rings and cylinder wear
May 8, 2010 at 12:58 PM
