Red bolt lights turned on
225,000 MILES • 3.3L • V6 • AUTOMATIC
VYTAUTAS SKAVICIUS
Hello. I have problem, I have red bolt lights on my car. I change fuel injection Throttle Body but light it is still on after 5 minutes when I turn on my car the bolt start lighting. Do you have idea what it could be? And is one more yellow light too. Sometimes is difficult to turn on my car.
Thank you!
Sep 6, 2019 at 4:10 AM
Can you take a picture of the lights that you are talking about so that we can be on the same page? Also, can you have it checked to see if there are any codes in the system? More than likely you have codes that will point us in the correct direction. If you don't have the ability to pull the codes then most large parts stores can pull them for you.
Also, I will have your email and phone number removed because this is a public website and we don't want you personal information out there when others read this post. Thanks
Sep 6, 2019 at 9:45 AM
VYTAUTAS SKAVICIUS
This.
Sep 6, 2019 at 9:52 AM
VYTAUTAS SKAVICIUS
I can't find codes.
Sep 6, 2019 at 9:53 AM
Okay. Unfortunately, we will just be guessing unless we can get the codes. This is the throttle light and check engine light. There are thousands of things that can turn the check engine light on. There are less that can turn both the throttle light and check engine light on but again, there is no way we can guess what the issue is without the codes. Once we get those, we can start to limit down what could be the issue.
If you are not able to get the codes, most parts stores can pull them for you. If not, then we will need to take it to a shop and get the codes.
Sep 6, 2019 at 10:57 AM
