1997 Dodge Eagle Vision
18,000 MILES • V8 • 2WD • AUTOMATIC
TOMHOLSTEIN
MY ENGINE LIGHT STAYS ON AFTER HAVING A WATER PUMP REPLACED AND ENGINE MISSES.
Jul 14, 2009 at 9:10 AM
  • 31,937 POSTS
HI there,
Thank you for the donation,
The engine light is a visual indication that the ECU has logged a fault code, the first thing you must do is get a scan done to read this code as it will be an indication as to where the problem is, do this first and post the code here.
mark (mhpautos)
Jul 14, 2009 at 10:27 PM
