MY ENGINE LIGHT STAYS ON AFTER HAVING A WATER PUMP REPLACED AND ENGINE MISSES.
Jul 14, 2009 at 4:10 PM
✓ASE Certified Mechanic
HI there,
Thank you for the donation,
The engine light is a visual indication that the ECU has logged a fault code, the first thing you must do is get a scan done to read this code as it will be an indication as to where the problem is, do this first and post the code here.
mark (mhpautos)
Jul 15, 2009 at 5:27 AM
