1995 Eagle Talon Won't Upshift at 35 MPH
REDWINGS20018
I have a 1995 eagle talon esi 2.0 automatic transmission. I be driving along and when i hit the 35 to 40 mph. its wants to downshift and not upshift. I pull over kill the car, start it back up and it shifts fine. Please give some tips. I have already tried cleaning the groung to the transmission (just replaced cable). It helped my friends same problem but in a Dodge.Please Help!!!!
Feb 5, 2007 at 8:49 AM
D_FRAS
i knew someone that had a similar problem only in a different kind of car. you might want to check the cars computer
Feb 20, 2007 at 3:21 PM
CARUNDELL
  • 602 POSTS
[quote:d1c92a83db="redwings20018"]I have a 1995 eagle talon esi 2.0 automatic transmission. I be driving along and when i hit the 35 to 40 mph. its wants to downshift and not upshift. I pull over kill the car, start it back up and it shifts fine. Please give some tips. I have already tried cleaning the groung to the transmission (just replaced cable). It helped my friends same problem but in a Dodge.Please Help!!!![/quote:d1c92a83db]
Hey red
There is a separate computer controlling the tranny. (TCM) and if you need it I can send along the procedure for manually pulling codes from the tranny control module. Let me know!
Chris
Feb 20, 2007 at 9:11 PM
Suggested Repair
Check the separate transmission control module (TCM) and retrieve transmission codes before replacing parts.
Conversation Summary
The owner of a 1995 Eagle Talon ESI 2.0 automatic says it wants to downshift and will not upshift around 35-40 mph until the car is shut off and restarted. Cleaning and replacing the transmission ground cable did not fix it. A reply suggested checking the computer, and the expert identified a separate TCM and offered the procedure for manually pulling transmission codes.
