1993 Dodge Dynasty Car won't start when it gets cold
119,002 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERTJ
I have a 1993 Dodge Dynasty 3.3 litter engine, and I have a terrible time starting the engine when it gets below 39 degrees and the colder the harder it gets to start the engine up to nine tries befor the engine catches, any Ideas as to why, I went to my mechanic and eveything was fine and no error codes from the ECM.
Help!!!!!
Robertj
Mar 7, 2008 at 11:59 AM
BMRFIXIT
  • 19,053 POSTS
test the fuel for Moisture (water)
fuel leak??
is it due for tune up ?
check the battery
if it crank slow it will take longer for it to start
Mar 7, 2008 at 12:21 PM
BLACKOP555
  • 10,386 POSTS
I would also like to add if the above tests out good then it is probably a bad coolant temperature sensor.
Mar 7, 2008 at 12:48 PM
BMRFIXIT
  • 19,053 POSTS
[quote:4dde33bdb8="blackop555"]I would also like to add if the above tests out good then it is probably a bad coolant temperature sensor.[/quote:4dde33bdb8]and or map sensor
Mar 7, 2008 at 12:51 PM
ROBERTJ
I am sorry it took me so long to get back and read these replies, First this model does not get tune ups as it is self tunning, and I will try the map sensor I'm not sure what a coolent sensor would have to do with a cold engine as it is only when it is cold that it does not want to start starting at 39 degrees or so and like I said the colder the harder it is to start
Mar 18, 2008 at 11:20 AM
MASTERTECHTIM
  • 4,750 POSTS
are you serious, a self tuning engine? the coolant temp sensor should be on top of your list of things to check. if the coolant temp sensor is reading too high of a coolant temp it wont deliver as much fuel needed to start a cold engine. recheck your findings and get back to us. remember were here to help and have been doing this a long time my friend.
Mar 18, 2008 at 11:24 AM
ROBERTJ
thanks I'll do that and does my car do a self tune or do I need to have it dune? when I bought the car the used car dealer said it was self tunning and I never questioned the statement, I need to know it is?
[quote:509117a13f="mastertechtim"]are you serious, a self tuning engine? the coolant temp sensor should be on top of your list of things to check. if the coolant temp sensor is reading too high of a coolant temp it wont deliver as much fuel needed to start a cold engine. recheck your findings and get back to us. remember were here to help and have been doing this a long time my friend.[/quote:509117a13f]
Mar 18, 2008 at 11:36 AM
MASTERTECHTIM
  • 4,750 POSTS
its definitely not a self tuning engine. the engine will learn your driving habits but the spark plugs etc still wear out. wow that was one crafty salesman.
Mar 18, 2008 at 11:41 AM
BLACKOP555
  • 10,386 POSTS
as tim says theres no such thing as a self tuning engine.
as with just about all vehicles they will learn you driving habbits.
but a self tuning engine does not exist especially in a 1993 vehicle!
Mar 18, 2008 at 12:25 PM
BMRFIXIT
  • 19,053 POSTS
Self timing yes
self tuning defiantly no noway impossible
they have not invented the engine that can change its own spark plugs and filters yet
(that I know !)
the PCM adjust and tune the timing and no need for any adjustment
PCM relay on reading from sensors to determine the fuel ratio
like in older car when you had the choke on 1st start or when cold
all I add is make sure your fuel is free of moisture
and have the tune up checked
good luck
Mar 18, 2008 at 1:46 PM
ROBERTJ
I went to the mechanic today and replaced the sensor and it was not it, it is now apparent that when the mechanic charged the system manualy it would start and when he tried it just with the car systems it would not start, the fuel pump and all that is requered to charge the system worked fine, so now it is somethat is not being done to tell the ECM to charge the system, any Ideas?
Mar 27, 2008 at 3:34 PM
WESTGUY
  • 16 POSTS
buy a battery warmer as it made a difference with mine especially in the west where i live and never believe one word that comes out of a car dealers mouth..there not mechanics they just want your money for crap cars and when im on line im available to answer questions with no wait.
Sep 29, 2008 at 11:35 AM
