1993 Dodge Dynasty Car won't start
CASPER48*
Engine Performance problem
1993 Dodge Dynasty 6 cyl Two Wheel Drive UNKNOW miles
My car cranks the same and sounds the same but won't start. My battery is so so it run down if it sets for a day or two but it will charge up. I've tried changing the coil ignition and nothing. I change the middle coil wire and nothing. It just tries to start but won't. I'm trying to narrow down the problem.
Aug 4, 2010 at 2:20 PM
  • 75,988 POSTS
You have a short that's draining the battery overnite-No start do below to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Aug 4, 2010 at 10:03 PM
