1992 Dodge Dynasty Won't idle
1992 DODGE DYNASTY
120,000 MILES • 6 CYL • FWD • AUTOMATIC
INSOM63
It won't idle unless you are pressing the gas peddle,even when I am driving it goes just fine,but if I lift my foot it will die.I have checked for vacuum leaks and don't seem to find any.The manual is useless so I would apreciate any help.Thank you for your time.
Feb 12, 2010 at 12:55 AM
CARADIODOC
  • 34,381 POSTS
If it will run if you hold the gas pedal down, the battery was likely disconnected or run dead. "Minimum throttle" must be relearned by the engine computer before it will know when it must be in charge of idle speed. To meet the conditions necessary for the relearn procedure to occur, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals.
If this doesn't help, the air passage around the throttle blade could be plugged with carbon. This used to be a common problem with the 3.0L engine years ago when fuels went as clean as they are today.
caradiodoc
Feb 26, 2010 at 12:04 AM
