1992 Dodge Dynasty STALLING
250,000 MILES • 6 CYL • FWD • AUTOMATIC
MICHAELD432
my car will run for a few minutes then it will just die and i have to sit and wait for about an hour or longer before it will start again, and it gets worse when the temp is over 90 degrees. I put a new coil pack on it but not sure what else to do can someone please help me.
Aug 10, 2008 at 1:57 AM
BLACKOP555
  • 10,386 POSTS
its kinda a good thing that the vehicle will not start right away after stalling because that gives you time to check weather its spark/ignition related or if it is related to the fuel delivery sytem.
to check for spark use a spark tester check all cylinders not jsut one will take about 10 minutes to do..
to check for fuel use a fuel pressure check guage, get back to me.
Aug 10, 2008 at 4:22 AM
