1991 Dodge Dynasty Shudders While Shifting 1-2 and Reverse
115,000 MILES • 6 CYL • FWD • AUTOMATIC
PROPROD
First, I'm not sure whether my Dynasty has the A413 or A604 transaxle. It's a 1991 3.3L. Has 1-2-3-D
This started suddenly and seems to be getting worse.
While shifting from 1st to 2nd, the car shudders a bit at a higher acceleration rate. When taking off slowly, it does not.
At a stop light, the car seems to drop into Neutral (even though it really hasn't), almost as if there is a gear lower than 1st, takes a bit more gas to get going from this state.
When placed into Reverse, the car acts as if the emergency brake is on. Lot of gas to reverse and when gas is removed stops suddenly.
Fluid level is good.
Nov 23, 2009 at 11:39 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect low oil pressure and tranny oil pumpor tranny internal seals
should check tranny fluid line pressure
remove the transaxle oil pan and inspect for the presence of clutch friction material in the bottom of the pan. If clutch friction material is present tranny need to be rebuilt
Nov 23, 2009 at 12:05 PM
