1991 Dodge Dynasty Problems with lights.
1991 DODGE DYNASTY
CLOWNBOY
1991 Dodge Dynasty 6 cyl Two Wheel Drive Automatic
I am having problems with my lights. After a few minutes my head lights will turn off and then flicker back on. This continues the remainder of the time that I have them on. I have found that if I turn the brights on or off and continue to hold the multifunction switch in that position the lights will not turn off until I release the switch. Also, the right turn signal works sometimes and sometimes it doesn't. I also replaced the multifunction switch, but the problem continues. Where do I go next?
Aug 29, 2009 at 6:11 PM
JDL
  • 16,098 POSTS
Just for testing, I'd bypass the multifunction switch, see if I could get the lights to work? If they do, it is the multifunction switch. From your post, it sounds like the multifunction switch?
Aug 30, 2009 at 3:24 AM
