1991 Dodge Dynasty no spark or injector pulse
310,000 MILES • 6 CYL • FWD • AUTOMATIC
CSTAPOLIS
have fuel pressure wiring checks good no codes can spark cylinders from scanner not injectors tried computer also tried 94 dodge 2.5 computer have spark and injector pulse 94 does not use cam sensor if timing chain has jumped will cam/crank sync not allow spark or injector pulse owner said car backfired twice then quit
Feb 17, 2010 at 12:25 AM
  • 75,988 POSTS
Hi cstapolis, Welcome to 2carpros and TY for the donation
Inspect and test the auto shutdown relay thoroughly it powers the injector and the coil-let me know
Feb 17, 2010 at 7:28 AM
CSTAPOLIS
auto shut down relay has been checked injector wiring good scanner will make each cylinder spark but no injector operation from scanner
Feb 17, 2010 at 8:10 AM
  • 75,988 POSTS
Check the injector solenoid resistance if okay could be the computer injector ground driver circuit.
Feb 17, 2010 at 8:22 AM
CSTAPOLIS
removed timing cover chain had jumped 2 teeth put new chain and gears on vehicle started just fine
Feb 23, 2010 at 9:44 AM
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
Mar 2, 2010 at 4:41 AM
