1991 Dodge Dynasty Heater core replacement
1991 DODGE DYNASTY
FCHEATUM
Engine Cooling problem
1991 Dodge Dynasty 6 cyl Two Wheel Drive Automatic
How do I replace the heater core? Usually they are on the passenger side, but the hose connections are toward the driver's side in the engine compartment. Before I tear things apart, I wanted to find out the simplest way to get it done. Thanks.
Sep 6, 2010 at 1:36 AM
WRENCHTECH
  • 20,761 POSTS
SIMPLE is not in the vocabulary for this one. In order to change the core you have to first remove the entire dash, then remove the entire HVAC housing and disassemble it. Not a job for a beginner at all.
Sep 6, 2010 at 2:38 AM
