1991 Dodge Dynasty can you help
BIGGERSLAM
  • 6 POSTS
1991 Dodge Dynasty 6 cyl Front Wheel Drive Automatic N/a miles
my speedometer works some if the time so I replaced the vehicle speed sensor and the other two sensor that are on the transmission and is stall works some if the time
May 5, 2009 at 4:56 PM
  • 110,248 POSTS
I believe the speedo runs from a cable that is gear driven in the trans on a 1991. Check under the dash to see if there is a cable running to the speedo area of the car. Let me know what you find.
May 13, 2009 at 4:51 AM
BIGGERSLAM
  • 6 POSTS
[quote:0e545a9de3="Jacobandnickolas"]I believe the speedo runs from a cable that is gear driven in the trans on a 1991. Check under the dash to see if there is a cable running to the speedo area of the car. Let me know what you find.
Joe[/quote:0e545a9de3]
Hi my 91 dodge dynasty has no cable running the speedometer i think it ran by a computer so can you help me still
May 13, 2009 at 4:13 PM
  • 110,248 POSTS
If the speedo is run from a speed sensor and you replaced it, chances are the cluster is bad. You will need to have that checked.
May 14, 2009 at 5:28 AM
BIGGERSLAM
  • 6 POSTS
[quote:9d2cf4634b="biggerslam"][quote:9d2cf4634b="Jacobandnickolas"]I believe the speedo runs from a cable that is gear driven in the trans on a 1991. Check under the dash to see if there is a cable running to the speedo area of the car. Let me know what you find.
Joe[/quote:9d2cf4634b]
Hi my 91 dodge dynasty has no cable running the speedometer i think it ran by a computer so can you help me still[/quote:9d2cf4634b]
biggerslam
thank you and I will try that and if i need more help i will ask again thank you again
May 14, 2009 at 10:32 AM
BIGGERSLAM
  • 6 POSTS
[quote:c87ed8d861="biggerslam"][quote:c87ed8d861="biggerslam"][quote:c87ed8d861="Jacobandnickolas"]I believe the speedo runs from a cable that is gear driven in the trans on a 1991. Check under the dash to see if there is a cable running to the speedo area of the car. Let me know what you find.
Joe[/quote:c87ed8d861]
Hi my 91 dodge dynasty has no cable running the speedometer i think it ran by a computer so can you help me still[/quote:c87ed8d861]
biggerslam
thank you and I will try that and if i need more help i will ask again thank you again[/quote:c87ed8d861]
biggerslam where is the cluster at And can you show me a pic if not that is fine
May 14, 2009 at 7:34 PM
  • 110,248 POSTS
The cluster is the insturments that the speedo is part of.
May 15, 2009 at 2:59 AM
BIGGERSLAM
  • 6 POSTS
[quote:72ce5f1d3b="Jacobandnickolas"]The cluster is the insturments that the speedo is part of.[/quote:72ce5f1d3b]
biggerslam
thank you
May 15, 2009 at 8:04 AM
CARADIODOC
  • 34,414 POSTS
Electronic automatic transmission controller (EATX) can also cause no speedometer.
May 28, 2009 at 6:57 PM
BIGGERSLAM
  • 6 POSTS
[quote:834092b7b9="caradiodoc"]Electronic automatic transmission controller (EATX) can also cause no speedometer.[/quote:834092b7b9]
biggerslam
thank you but I have fix it it was the speedometer head culster
May 29, 2009 at 4:25 PM
