1991 Dodge Dynasty can you help
BIGGERSLAM
  • 1991 DODGE DYNASTY
1991 Dodge Dynasty 6 cyl Front Wheel Drive Automatic N/a miles
my speedometer works some if the time so I replaced the vehicle speed sensor and the other two sensor that are on the transmission and is stall works some if the time
Tuesday, May 5th, 2009 AT 11:56 PM
  • 109,885 POSTS
I believe the speedo runs from a cable that is gear driven in the trans on a 1991. Check under the dash to see if there is a cable running to the speedo area of the car. Let me know what you find.
Wednesday, May 13th, 2009 AT 11:51 AM
BIGGERSLAM
  • 6 POSTS
Hi my 91 dodge dynasty has no cable running the speedometer I think it ran by a computer so can you help me still
Wednesday, May 13th, 2009 AT 11:13 PM
  • 109,885 POSTS
If the speedo is run from a speed sensor and you replaced it, chances are the cluster is bad. You will need to have that checked.
Thursday, May 14th, 2009 AT 12:28 PM
BIGGERSLAM
  • 6 POSTS
Hi my 91 dodge dynasty has no cable running the speedometer I think it ran by a computer so can you help me still[/quote:9d2cf4634b]
biggerslam
thank you and I will try that and if I need more help I will ask again thank you again
Thursday, May 14th, 2009 AT 5:32 PM
BIGGERSLAM
  • 6 POSTS
Hi my 91 dodge dynasty has no cable running the speedometer I think it ran by a computer so can you help me still[/quote:c87ed8d861]
biggerslam
thank you and I will try that and if I need more help I will ask again thank you again[/quote:c87ed8d861]
biggerslam where is the cluster at And can you show me a pic if not that is fine
Friday, May 15th, 2009 AT 2:34 AM
  • 109,885 POSTS
The cluster is the insturments that the speedo is part of.
Friday, May 15th, 2009 AT 9:59 AM
BIGGERSLAM
  • 6 POSTS
Biggerslam
thank you
Friday, May 15th, 2009 AT 3:04 PM
CARADIODOC
  • 33,916 POSTS
Electronic automatic transmission controller (EATX) can also cause no speedometer.
Friday, May 29th, 2009 AT 1:57 AM
BIGGERSLAM
  • 6 POSTS
Biggerslam
thank you but I have fix it it was the speedometer head culster
Friday, May 29th, 2009 AT 11:25 PM
