1990 Dodge Dynasty wont start
WAYNE43
  • 1990 DODGE DYNASTY
  • 6 CYL
  • 285,000 MILES
My car was going fine then just shut off?When I turn key part way I can the fuel filter kick on. But just wont start. Turns over great.
Saturday, March 20th, 2010 AT 1:46 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Saturday, March 20th, 2010 AT 2:53 PM
