1990 Dodge Dynasty leak at front of engine
1990 DODGE DYNASTY
ANDY MALDING
Engine Cooling problem
1990 Dodge Dynasty 6 cyl Front Wheel Drive Automatic
I do not find the water pump drive pulley..so I can locate it ...Is it driven by the timing belt..If so which side of the engine will I find it I know their usaly in the center above the crankshaft...?
May 4, 2008 at 12:18 PM
  • 110,244 POSTS
Hi:
The water pump is located on the passanger side. Also, what size engine does the car have?
Nov 4, 2008 at 4:41 AM
