1989 Dodge Dynasty No radio or cluster lights
1989 DODGE DYNASTY
JTHATFASTGUY
Electrical problem
1989 Dodge Dynasty 6 cyl Front Wheel Drive Automatic
Yes i have an 89 dynasty my cluster panel and radio seem to work when they see fit i have look all over for loose wires and or problems fuses are good there is power everywhere even going to the radio i am lost to where to look next only thing i can think of is a faulty headlight switch could and would this be the problem rest of lights work just not the cluster panel i could really use some sound advise
Sep 17, 2008 at 5:30 AM
  • 110,244 POSTS
Hi:
If the radio works but its light goes out along with the other cluster lights, you are most likely right. It could be the switch. It sounds like you already looked under the dash for loose wires, the fuse is good, and the radio still works, so it's either the switch or a ground problem.
If you decide to replace the switch and need help, let me know.
Oct 24, 2008 at 8:20 AM
