1989 Dodge Dynasty Lack of power
36,000 MILES • 6 CYL • 2WD • AUTOMATIC
PYEHLE
I just bought this 89 Dodge Dynaty yesterday. It belonged to and older couple that can't drive anymore.Its in really nice shape. The car sat alot in the garage and got little use if any the pasted two years. If I push the accelrator down past 1/4 she stumbles and falls flat on her face. If I hold the throdle wide open in nutreal it won't rev up enought to even worrie about causing engine damage from over reving. it starts hard espicaly after it's warmed up. It feels like its running lean, some times if I push it to hard it will back fire through the intake. I put a bottle of injector cleaner in the tank last night. Do you have any other ideas what this might be? Thank you. Paul
Mar 23, 2010 at 7:39 AM
LEGITIMATE007
  • 5,121 POSTS
I would suspect several items would need some cleaning and changing. is there a check engine light on?
Mar 30, 2010 at 1:55 AM
PYEHLE
No check engine. The engine starts fairly easy if I start it right back up,if it sits 20 or more minutes it start real hard. Im starting to think fuel pressure regulator. I didnt chnge fuel filter yet, but 1st I think I will check the fuel pressure before and after the filter.
Mar 30, 2010 at 2:14 AM
LEGITIMATE007
  • 5,121 POSTS
correct, check it before and after, and listen for the fuel pump to come on when you turn the key to the start posiiton
Mar 30, 2010 at 5:17 AM
LEGITIMATE007
  • 5,121 POSTS
