1989 Dodge Dynasty fuel delivery system
THEDOC
Electrical problem
1989 Dodge Dynasty 6 cyl Front Wheel Drive Automatic
I have a 1989 Dodge Dynasty. The other day the car failed to start. I replaced the fuel pump to no avail. I checked the voltage at the fuel pump and the harness is delivering 4.8 Volts. To check the new pump I hooked a 2amp direct connected charge to the pump and it spun up by using a trickle charger but even though it powered up no fuel was delivered through the fuel line (known because I removed the fuel line from the fuel filter to check fuel flow). Could I have hooked the pump up with reversed polarity causing the pump to work backwards? Where do I look next for this problem? I am frustrated to the max. Thank you for your assistance.
Oct 27, 2008 at 3:10 AM
  • 75,988 POSTS
Hi thedoc and welcome to 2carpros
Get a wire long enough to reach the fuel pump connector dark green and black wire other end hook it up on the battery positive terminal and tell me what happened-fuel pump comes On but still no pressure-recheck the fuel pump then get back with some results so that we can continue-
Oct 27, 2008 at 9:05 AM
