1989 Dodge Dynasty car repair
155,000 MILES • 4 CYL • FWD • AUTOMATIC
CONNIE35
my dodge dynasty starts then dies. we've changed cam shaft, emptied gas tank and replaced with new gas treatment and gas, changed fuel filter, gets fuel to throttle body, checked spark plugs, checked timing beltm, runs a few seconds longer by manually pouring gas into throttle body, done code check- no codes, can hear fuel pump kick in, took out catalyic convertor, checked fuses, replaced fuel pressure regulator. what could be the problem?
Mar 20, 2008 at 2:21 AM
LEGITIMATE007
  • 5,121 POSTS
check Idle air control valve and crank position sensor.
Mar 20, 2008 at 5:36 AM
