vss wire location for nav. system 04 durango hemi
KBDC8297
i am looking for the vehicle speed sense wire location and/or color so i can connect my nav. system to my 2004 durango hemi. aprox. 40,000 miles. the local dealer says that the one that is in the engine comp. will drain the battery after a few days if i was to tap into it. they said there is another one on the trans. and the rear axle. but didnt tell me which one ,location, and color.
Nov 4, 2006 at 1:33 PM
SPARKS83
Go buy a new radiator. It will be cheaper and faster in the long run.
[quote:bd166c5288="susie22"]my radiator has a hole in the front grill, can i take this to a shop to be repaired?[/quote:bd166c5288]
Jun 11, 2006 at 1:19 PM
SENSE-A
radiators are fairly easy to replace. Takes about two hours on the weekend for an amatuer.
get one from autozone or a local cheap parts dealer. Do it yourself. Or if getting under the hood scares you it should cost $200 at the most unless a mechanic is trying to milk you.
When I bought my acura used it had a plastic radiator! lol at least I put a good one in there for about $100 total.
Aug 7, 2006 at 8:14 AM
