2003 Dodge Durango Airbag Light
BUSHWACKER
2003 Durango w/ 4.7L w/ 55K. My airbag light came on and I was told it was the clock spring, which I had replaced. The light came on again in ~ 4 mths and was replaced for free. Its been 1 year and again the light is coming on intermittently. 1) If the light comes on, is it always the clock spring? 2) If so, is it possible that contact surfaces are wearing and the unit isn't actually bad? I don't want to have it replaced if its a matter of assuring the mating surfaces are true.
Apr 9, 2007 at 6:27 AM
BRUCE HUNT
  • 3,754 POSTS
The clock spring in these cars goes out which causes the light to come on but to make sure that is the problem again lets rung the codes please follow this video.
https://youtu.be/gnSGfEqrf_w
And if the clock spring is bad this guide will help you replace it.
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Please run down this guide and report back
Cheers
Jan 20, 2007 at 9:56 AM
OMPBSD
thanks for the help,,i went and checked things and the code was for the driver side airbag circuit so the clock spring is out ...again.
Jan 21, 2007 at 10:33 AM
SERVICE WRITER
  • 9,123 POSTS
We replaced a clock spring in a 03 Chrysler last week for the same thing. The customer did hear a "pop" just before the problem occur ed on a tight turn..
Apr 9, 2007 at 10:50 AM
BJB5555
is there a way to turn off red air bag light with-out dealer involvement, or is service - repair needed for safety purposes.
Sep 1, 2018 at 4:46 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
When the SRS (red airbag lamp) comes on in the instrument panel and remains on, it indicates that the vehicle's computer has detected a problem with the SRS. The only way to reset the light is to scan the SRS with the proper diagnostic scan tools to retreive and clear the stored trouble codes, and to fix the issue at hand. The only alternative would be removing the instrument cluster to gain access to and remove the little bulb that lights up the SRS symbol.
WAYNE2341
air bag light wont go off air bags and clock spring elc. box replaced 2001 dodge durango
Sep 1, 2018 at 4:47 AM (Merged)
DR LOOT
  • 2,311 POSTS
are you able to scan to see what the codes are? maybe somebody hit you in the parking lot and you got a bad sensor and a front now
PEGGYM10
Interior problem
2001 Dodge Durango Four Wheel Drive Automatic
The airbag light comes on intermittently when driving the Durango. Is this a problem with the airbag or in the dashboard lights? How do I fix it?
2CARPRO JACK
  • 11,533 POSTS
You need to have the computer scanned to see if it is seeing a problem with the SRS system.If there is a problem, the system wont work properly in the event of an accident
IRISHWITCH1969
Electrical problem
2001 Dodge Durango V8 Four Wheel Drive Automatic
I cant get my air bag light to go off ant it wont pass inspection, help!!!!
  • 110,251 POSTS
Hi:
It sounds like a bad sensor. Have the vehicle scanned for trouble codes at a nationally recognized parts store. Most do it for free and it should let you know what is what is wrong.
Suggested Repair
Scan the SRS for trouble codes. A driver-side airbag circuit code indicates another failed clock spring, which should be replaced. Do not only clear the light or remove the lamp; the fault must be repaired so the airbags work.
Conversation Summary
A 2003 Dodge Durango owner had an intermittent airbag light return after two clock-spring replacements and asked whether worn contacts could be the cause. A scan showed a driver-side airbag circuit code, which experts attributed to another failed clock spring. Related replies stress scanning the SRS and repairing the fault rather than only turning off the warning light.
